Date/Time: Thu, 16 Jan 2025 00:15:31 +0000
study subgraph average
View Count: 1189
[2017-09-27 14:01:30] |
User98657 - Posts: 329 |
I have the Daily OHLC study on my chart. I also have a Study Subgraph Average study on the chart that looks for an average of the Daily High and the Daily Low resulting in the Mid of those two values. When i scroll back in my charts, at some point i lose the mid. At first i thought it was because i was scrolling into the previous contract (Futures, Continuous, Back Adjusted). But that's not it. the point at which i seem to lose the Mid appears to be arbitrary in length. Yesterday i was scrolling back to do some research and i could see the mid as far back as 8/1/2017. An hour later i couldn't get it to appear before 8/7/2017. Looking for thoughts as to why i might be experiencing this. Date Time Of Last Edit: 2017-09-27 14:10:27
[2017-09-27 18:25:03] |
Instead use the method documented here to view the High Low Average: Daily OHLC: Displaying Midpoint of High and Low Lines The most likely reason for the issue you are seeing though would relate to study calculation order/precedence: Chart Studies: Study Calculation Precedence And Related Issues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-27 18:26:29
[2017-09-27 19:21:56] |
I did as you suggested and just used the subgraph on the Daily OHLC study. But that still only allows me to see the mid back to 8/9/2017. I've also noticed i'm losing the High of Day and Low Of Day lines, so for whatever reason i seem to be losing the ability to see the high and low. i can still see the bars of course, but the study stops working X days back.
[2017-09-27 19:24:06] |
Check the Number of Days to Calculate input with the study.
