Date/Time: Thu, 16 Jan 2025 00:15:12 +0000
ACSIL - indicator working only on visible bars
View Count: 935
[2017-09-27 13:14:16] |
Artur - Posts: 2 |
Hello, Due to performance issues I need to update my indicator only with visible bars data. It is possible with ACSIL to get only visible bars and update indicator when view changed? (eg. spacing changing, chart scrolling, new bar created). Thank you Date Time Of Last Edit: 2017-09-27 14:40:00
[2017-09-27 18:17:07] |
Have a look at using this function: sc.GetBarHasClosedStatus() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
