Date/Time: Wed, 15 Jan 2025 23:59:19 +0000
Number Bars
View Count: 643
[2017-09-27 12:11:25] |
User571894 - Posts: 1 |
Hi I am using the latest version of Sierra charts but wanted to know if it is possible to run an older version of Sierra Charts for my number bars but still have the two charts linked. To clarify: I wish to use older version setting of Sierra for my Number Bars chart but still, have the chart in my latest 2017 version of Sierra charts Thanks |
[2017-09-27 17:58:14] |
You can run two copies of Sierra Chart separately and each can be a different version. Also refer to: Number bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-27 17:58:49
