Date/Time: Thu, 16 Jan 2025 00:11:20 +0000
General Questions
View Count: 692
[2017-09-27 09:01:06] |
User39772 - Posts: 311 |
Activity Log: Is it possible to send data from an automated trading system (e.g. spreadsheet) to the Activity Log, e.g. every time an order is executed, so that I have an additional column in the activity trade log with that data ? Export/Import: When I use Export Bar/Study data and import it again, the study data is not visible any more in the chart. Is there another way available to "feed" SC with my own price data without the need for a real data feed ? |
[2017-09-27 20:04:34] |
1. Have a look at using the Text Tag: Automated Trading From an Advanced Custom Study: [Type: SCString] TextTag 2. You definitely cannot import study data. 3. You could create a DTC Protocol Server to provide your own data feed to Sierra Chart: Data and Trading Communications (DTC) Protocol Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-27 20:05:45
