Date/Time: Thu, 28 Nov 2024 15:42:31 +0000
Alert for Bar Duration < :10
View Count: 1743
[2017-09-26 22:12:45] |
SithTrader - Posts: 6 |
Support, I use Renko bars with a numbers bars calculated values study. I track "bar duration" as one of the subgraphs. I'm looking to create an alert with an arrow when a bar is equal to or less than ten seconds. I've referenced the TIME functions, but I'm not able to make anything work on my end. Any help would be greatly appreciated. Thank you.. |
[2017-09-27 19:55:57] |
You need to use the Color Bar Based on Alert Condition study: Color Bar Based on Alert Condition This is the formula you will need to use: ID#.SG30 < TIME(0, 0, 10) The # needs to be replaced with the ID number of the Numbers Bars Calculated Values study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-27 19:56:23
[2017-09-27 20:00:04] |
You also need to enable the Use Full Precision when Evaluating Alert Formula Alert option.
[2023-04-20 21:10:34] |
brainscan132 - Posts: 5 |
Hi there, hopefully this is a very quick question. I also wanted the above study but I want to extend the relevant bars to the right until future intersection... I have my study settings as per the picture. I can't think why the extension lines are not appearing. I have been tweaking the settings to no avail and I couldn't see another post asking this question. Any assistance would be appreciated :) |
EXTEND BAR QUERY.png / V - Attached On 2023-04-20 21:07:06 UTC - Size: 648.26 KB - 91 views |
[2023-04-20 21:34:00] |
You have the Input for "Output when Condition True" on the Color Bar Based on Alert Condition set to "1.0". Therefore, your extension lines are being drawn at a value of 1.0. You need to change that to the value of what you are wanting to see. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
