Date/Time: Thu, 13 Feb 2025 19:46:40 +0000
Weekly TPO Profile Letter Coloring
View Count: 1362
[2017-09-26 18:52:37] |
MichaelPPTF - Posts: 69 |
Hi, me again :-) I am using the TPO profile to chart the weekly MP with 30M periods during RTH session, which is 405 minutes For each day, there will be 14 letters, from A-N. Is there a way to assign one color to each day's TPO? For example, Monday A-N will be green and Tuesday will be red and so on? I can only find option to color each letter individually but the letters will be repeating itself between days so that defeats the purpose. Thanks! |
[2017-09-27 02:58:36] |
Your Sierra Chart account is expired.
[2017-09-27 03:01:00] |
I am a paid customer with Infinity and I do not know how to use that credential to login.
[2017-09-27 17:32:54] |
This method of coloring is not supported unless you set this Input to 1440: Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Time Period Length in Minutes (for Intraday Charts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-02 09:54:53] |
We thought about this, and we implemented it. It will be out in the next release. Here is an example: http://www.sierrachart.com/image.php?Image=1506937933586.png It is a new setting in the TPO Letter/Block Colors Input with the study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-02 13:38:13] |
Looks gorgeous. Thanks!
[2017-10-02 17:42:36] |
Again, Sierra Techs, I appreciate you guys' quick response to this feature suggestion and I do understand the enormous development workload you have there. Good job!
[2017-10-02 17:48:19] |
SithTrader - Posts: 6 |
This will be a great feature.. thank you for adding this!
[2017-10-02 17:51:39] |
OK.
[2020-12-22 04:21:47] |
User202416 - Posts: 37 |
I am not able to bring daily TPO in different color in weekly TPO
[2020-12-22 15:03:57] |
John - SC Support - Posts: 37939 |
You need to set the Input for TPO Letter/Block Colors to Use Letter/Block Color 1-18 for Days of the Week. Refer to the information here: Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Colors For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-23 08:28:37] |
Letter block color 1 is reserved for Sunday in weekly . By ignoring this I am able to bring 5 different colors for Monday to Friday in weekly
