Date/Time: Wed, 15 Jan 2025 21:36:50 +0000
Difficulty Loading indices with Sierra Data Feed
View Count: 617
[2017-09-26 18:38:34] |
knoxville1915 - Posts: 38 |
Hi, I'm having difficulty loading real time data for indices, Nasdaq in particular. I've tried $NASX but it does not load with the [M] symbol. I've also tried NASX-IND-NASDAQ to no avail. Individual stocks load fine.
[2017-09-26 18:45:17] |
Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CashIndexes You will need to activate the NASDAQ Indices exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
