Date/Time: Thu, 16 Jan 2025 00:10:37 +0000
SC Data feed
View Count: 824
[2017-09-26 17:40:12] |
User240686 - Posts: 86 |
Hi I am an AMP client but was wondering for my long term analysis if I could get the Free EOD data feed enabled? Thanks Andrew |
[2017-09-26 17:50:06] |
You will need a direct Sierra Chart account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-26 18:27:39] |
so to get the EOD data is that a free service? I am not quite understanding
[2017-09-26 18:37:00] |
Sierra Chart is not free. For what exchanges do you want Historical Daily data for?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-26 18:37:27
[2017-09-26 19:07:08] |
CL and Treasuries
[2017-09-26 21:19:41] |
Your account already includes Historical Daily data for these exchanges. You just open a chart through File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-27 06:49:42] |
Sorry i also meant to say the Forex market but if i cant get that then its no huge issue
Date Time Of Last Edit: 2017-09-27 06:50:13
[2017-09-27 06:59:39] |
The cash Forex market symbols are not included with your account type.
