Date/Time: Thu, 16 Jan 2025 00:04:11 +0000
Multitasking
View Count: 971
[2017-09-26 15:53:35] |
SPTrader - Posts: 4 |
Is Sierra Chart's multitasking? If so, at what level, e.g. chart level, indicator level, etc.
[2017-09-26 16:44:55] |
Probably what you are referring to is multiple threads and those are supported. In the way that they are supported is documented here: Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-29 15:39:16] |
To confirm, if SC is open with 6 embedded charts and all the data has been downloaded, that instance of SC and the 6 charts all run on a single thread? E.g., I have 3 ES time charts and 3 ES tick chart (range bars, volume bars - btw, do you support?), all six of those charts run on a single thread? If I want to split that up, I would need to open a second instance of SC and pay an additional fee for the extra connection(s). BTW, I have a 6/12 core Intel processor. I reserve one for order processing and 5 for charting. Additionally, does SC support cursor synchronization between instances? |
[2017-09-29 17:37:42] |
We really do not understand why this question is being asked. The problem is the technical explanation is involved and generally from the perspective of the user it is not relevant and you will draw incorrect conclusions. You should test your set up on Sierra Chart first and then if you have an issue you can refer to this page here: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart is not going to have any trouble running your set up in a single instance. You are improperly putting attention on something which is very likely to not be relevant. (range bars, volume bars - btw, do you support?) Yes. and pay an additional fee for the extra connection(s)
You do not have to pay an additional fee for other instances of Sierra Chart. Refer to:http://www.sierrachart.com/index.php?page=doc/NewInstance.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-29 17:51:31
[2017-09-29 17:50:50] |
The prior post has been updated.
