Date/Time: Sat, 25 Jan 2025 05:18:46 +0000
removing P& L display from trading dom
View Count: 1007
[2017-09-26 14:19:10] |
User875891 - Posts: 63 |
Could u please tell me how this is done?
[2017-09-26 17:47:40] |
You can set this through the Profit/Loss Format setting: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-26 17:52:10] |
Xfanman1 - Posts: 320 |
If you go to the Trade/Customize Chart/Trade DOM Columns you can add or remove it from there. http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOMPositionPLColumn |
[2017-09-26 18:31:51] |
The instructions linked to in the prior post are referring to the Profit/Loss column and not the single value displayed for the Open Position and Daily Profit/Loss.
