Date/Time: Wed, 15 Jan 2025 21:56:19 +0000
Trading the JSE
View Count: 1246
[2017-09-26 11:26:43] |
User172040 - Posts: 70 |
Hi, what would you need from me so that I can feed JSE (Johannesburg Stock Exchange) futures data and JSE equity data through the SC platform? Whatever you need, I can try and get it from the JSE
[2017-09-26 18:10:40] |
An interface would have to be developed between a provider of the data from the JSE or direct to that exchange. This is not really a simple process. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
