Date/Time: Wed, 15 Jan 2025 21:49:09 +0000
[Programming Help] - Strange spreadsheet output value for tick size J21
View Count: 1324
[2017-09-26 09:42:48] |
User841591 - Posts: 42 |
Pls note the attachment. I try to evaluate the H15 (=J21=0.0001). if tick size = 0.0001, the return should be true. However, it return false. Pls help on it
Attachment Deleted. ScreenHunter_03 Sep. 26 1 47.31.jpg / V - Attached On 2017-09-26 09:42:13 UTC - Size: 77.34 KB - 413 views |
[2017-09-26 16:21:33] |
Sawtooth - Posts: 4153 |
Sometimes the value in J21 contains floating point errors. Use this formula in H21 to remove them: =1/ROUND(1/J21,0) Then use this in H15: =H21=0.0001 |
[2017-09-26 16:43:52] |
Refer to: Using the Spreadsheet Study: Imprecision of Floating-Point Numbers and Comparisons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
