Date/Time: Wed, 15 Jan 2025 22:00:40 +0000
Question regarding NYSE and NASDAQ TICK data
View Count: 1478
[2017-09-26 03:44:54] |
User647013 - Posts: 1 |
I am currently attempting a Combine at TopStep and am using NinjaTrader. The data provider they use is Rithmic and that doesn't include NYSE or NASDAQ TICK data which I find helpful. I'm trying to find an inexpensive way to add that to my desktop. I recently configured those charts on a free trial run with Sierra Chart and it worked great. I'm wondering what the minimum data requirement and cost would be just to have those two charts running. If I could get some help with that I'd really appreciate it. Thanks, |
[2017-09-26 04:10:39] |
This data is included with all of the Sierra Chart Service Packages. Refer to: Sierra Chart Market Statistics The pricing can be found here: Description of Service Packages and Pricing You will just need the Standard service package. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
