Date/Time: Fri, 03 May 2024 03:07:53 +0000
[User Discussion] - ticker tape speed or bid/ask volume acceleration
View Count: 3816
[2017-09-26 03:31:48] |
User606491 - Posts: 164 |
Does Sierra Chart have an indicator that measures ticker tape speed? or the acceleration of bid and ask volume? thank you |
[2017-09-26 18:17:39] |
We would think that basing chart bars Number of Trades Per Bar would help with this. Refer to: Chart Settings: Time Period Per Bar / Amount of Data Per Bar (Chart >> Chart Settings >> Bar Period menu) There is also the Bar Duration study that can be used with these bars or any type of bar period: Bar Time Duration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-27 14:41:39] |
User136422 - Posts: 33 |
You could also look at the volume/sec subgraph in the numbers bar calulated values study for bid ask numbers bar. hope it helps
[2017-09-27 14:51:27] |
all of these are helpful. As always, thank you.
[2019-09-21 05:29:03] |
yellowandy - Posts: 20 |
User136422 do you have a working example of referencing the subgraph in code? Sorry for the noob question.
