Date/Time: Wed, 15 Jan 2025 22:00:43 +0000
sc.DataFile change not releasing realtime subscription
View Count: 926
[2017-09-25 23:57:17] |
Jagui1 - Posts: 14 |
SC version 1615 with IB real account and SC realtime datafeed enabled. Max 100 realtime symbols on both IB and SC realtime datafeed. I have a chartbook with 16 charts of NYSE stocks. In each of these 16 charts there is a custom indicator that periodically changes the chart symbol using sc.DataFile = ... After a total of approx 100 symbol changes, I start getting the 100 symbols limit reached error. I expect to never reach that limit, because there are only 16 charts and so I think that there are no more that 16 active realtime symbols at each moment in time. It seems like SC does not unsubscribe to realtime updates after having changed a chart symbol via sc.DataFile. Date Time Of Last Edit: 2017-09-26 00:05:03
[2017-09-26 00:24:29] |
Yes this is true. Refer to: Chart Data and Chart Data Files: Reducing Number of Symbols Being Tracked by Sierra Chart We possibly can add the capability for ACSIL to disconnect and connect to the data feed and maybe that would be a solution indirectly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-26 00:25:23
[2017-09-26 00:40:17] |
Is it possible to disconnect and reconnect to the trading service from ACSIL? This would be a quick workaround... |
[2017-09-26 00:45:33] |
...didn't see you already thinked about this solution :-)
[2017-09-26 01:38:23] |
We can see that the variables for reconnecting to the data feed in ACSIL already exist: sc.ConnectToExternalServiceServer; sc.ReconnectToExternalServiceServer; sc.DisconnectFromExternalServiceServer; We just need to add another variable indicating how many symbols that Sierra Chart is tracking. We will do that today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-26 01:39:48
