Date/Time: Wed, 22 Jan 2025 13:07:41 +0000
Pull/Stack Data for Alerts
View Count: 1627
[2017-09-25 14:03:56] |
TSiSVT - Posts: 21 |
Is there a way to access and use the pull/stack data on the DoM to create alerts and/or incorporate it into the spreadsheet? I've only managed to have it show the first bid and ask level. I would prefer to utilize at least 5 levels if not 10.
Date Time Of Last Edit: 2017-09-25 14:39:48
[2017-09-25 17:20:05] |
The data is accessible only through ACSIL: http://www.sierrachart.com/index.php?page=doc/Contents.php#AdvancedCustomStudySystemInterfaceandLanguage We will see about adding functions that simple alerts can use to access this data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-25 17:20:15
[2017-09-25 17:54:19] |
That would be good if you can. I would like to use this data but prefer not to get involved with ACSIL at this time.
[2018-09-28 00:51:50] |
User153286 - Posts: 49 |
any ETA of ability to alert on a bid/ask pull based on input size or % ?
[2018-09-28 01:11:08] |
tdd2672 - Posts: 61 |
Depth of Market Data study will provide 10 levels of bid/ask pulling/stacking on the spreadsheet. With that you can create formulas based on your criteria and use a combination of studies to provide what you may be looking for.
[2018-09-28 01:23:14] |
I do not see and have not found any docs on how to apply a formula to any column/cell in the DOM, is there any examples of this to read up on?
