Date/Time: Mon, 14 Sep 2026 05:19:16 +0000
ACSIL accessing tick-data sc.Index during System Replay Backtest mode
View Count: 2665
[2017-09-25 09:22:26]
User553714 - Posts: 184
I am running a "Auto Trade System Replay Backtest" on a 1-minute bar chart; the sc.Index is numbered in relation to the 1minute bars. Is there anyway to access the actual tick/data-record that each back test calculation is performed on, like a sub-index of the 1-minute bar index? My guess is that these are being accessed using their sc.DateTime and a sub-index between the 1minute bars is not maintained as the number of ticks would be different for every bar?
I am trying to understand exactly why a trade consistently triggers during a Bar-based test and Not during a Replay Backtest which is significantly more accurate; in order to be able to do this I need to access the data inside the 1minute bars, are there any provisions to do this as everything sc seems to be sc.Index based? Regards
[2017-09-25 17:13:38]
Refer to:
http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scGetTimeAndSales
That function describes a method to do this by using a separate chart with Number of Trades Per Bar set to 1.
Date Time Of Last Edit: 2017-09-25 17:13:53
