Date/Time: Thu, 16 Jan 2025 00:11:53 +0000
[User Discussion] - Renko
View Count: 1220
[2017-09-24 14:28:42] |
jizzary - Posts: 177 |
Hi can you please explain (or provide a URL) what is the difference between the "Graph Main Draw" (set to Renko Brick) and the Renk Study? Thanks |
[2017-09-25 04:58:28] |
We will not answer this question. Those particular Graph Draw Types should be removed and we will work on that in the coming weeks. Your account is also far over quota on support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-25 04:58:40
[2017-09-25 10:22:13] |
>Your account is also far over quota on support. don't agree. I have paid 1 year ahead, showing my support trust in you and I find your attitude improper towards me. Further, it is about time that you should see that I'm referring undocumented stuff and my questions are bringing ideas I request you to take another attitude towards me. I want to feel "at home". Currently, I can't feel that way. Date Time Of Last Edit: 2017-09-25 14:21:36
[2017-09-29 07:34:04] |
Sorry, I'm confused: On one hand, the documentation says the Renko-Study is considered obsolete and will be removed ("The Renko Chart study is an older study that has now been replaced with the new Bar Period Type >> Renko in Ticks setting. This study is considered discontinued and is unsupported by Sierra Chart"). On the other hand, you indicated above that "Those particular Graph Draw Types should be removed and we will work on that in the coming weeks.". So which one is here to stay? The "Renko-Study" or the "Graph Draw Bars" = Renko Bricks Thanks. |
