Date/Time: Wed, 15 Jan 2025 22:34:45 +0000
Linear Regression Channel issue
View Count: 1499
[2017-09-22 20:02:26] |
Devil_On_WallStreet - Posts: 67 |
I have a 150 period Linear Regression Channel... I just noticed that it changes position as I adjust the size of the window, meaning going from having my window taking up 1/3 vs maximizing the screen. The top line of the channel moves about 40 ticks. As the position should be set by the period length, I'm really confused as to why it is changing just from resizing the workspace????
[2017-09-23 10:54:24] |
Update to the latest "Prerelease" and let us know if you still see this issue. Here are instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
