Date/Time: Sun, 24 Nov 2024 02:43:50 +0000
chart order labels and lines right to left
View Count: 1557
[2013-09-06 18:00:30] |
Bruce Heubach - Posts: 16 |
I have selected to place the chart order labels on the right, so how do I extend the order price lines to the left. The default is labels on the left and lines extending left to right. Currently I have no lines as in the image enclosed. Thanks.
Image1.png / V - Attached On 2013-09-06 18:00:20 UTC - Size: 26 KB - 445 views |
[2013-09-06 18:40:43] |
When the orders are are aligned to the right, there will be no line that extends to the left.
