Date/Time: Wed, 15 Jan 2025 22:31:05 +0000
few questions
View Count: 669
[2017-09-22 02:09:25] |
User157806 - Posts: 71 |
Is it possible to increase the font size for the buttons on the tool bars? Also is it possible to have a new candle start at 6 pm on a daily chart? |
[2017-09-22 05:21:36] |
1. Yes. Refer to: Control Bar: Control Bar Buttons Size and Text Size 2. Yes. Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails12.html#h12.6 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
