Date/Time: Wed, 15 Jan 2025 22:59:12 +0000
acces to data
View Count: 821
[2017-09-21 20:52:07] |
User645807 - Posts: 2 |
hello, i would like to buy access to BATS exchange. look at the attachemnt. could you check my accoun tand answer schould i need other thing/package to use this exchange? |
Zrzut ekranu 2017-09-19 14.43.53.png / V - Attached On 2017-09-21 20:51:45 UTC - Size: 100.67 KB - 254 views |
[2017-09-22 05:13:11] |
You also have to pay for the data feed itself which is 35 USD per month. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing Here are the step-by-step instructions: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-22 05:39:00] |
thank you for answer. can i use at the beggining trial for real time data connection? will be bats exchange working on trial version?
[2017-09-22 07:25:35] |
Yes. The data feed trial for 5 USD, does support real-time data including real-time data from BATS.
