Date/Time: Wed, 15 Jan 2025 21:44:14 +0000
Color Bar Based On alert Condition - Draw Style do not dissapear
View Count: 1838
[2017-09-21 20:15:53] |
avifutures - Posts: 59 |
Hi, Color Bar Based On alert Condition configured as "Reset Alert Condition On New Bar" and "Number Of Bars To Calculate" = 1. This way I expect the Draw Style chosen (Triangle up/down in my case) to show only for the last bar, but it still remain there for the prior bars... If i open the "Studies to Graph" to see the studies list and then i press apply, all the prior triangles disappear except the last bar triangle (if exist). This is perfect but should be maintained automatically without the need to open the studies list and press the apply button. It seems like a bug... I am on version 1609. I will appreciate your assistance. |
[2017-09-22 05:14:32] |
We need to get this one particular chart using that study, to be able to test this. Follow the instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-22 09:56:37] |
File attached
Private File |
[2017-09-23 09:52:42] |
Refer to this Input for the study here: Color Bar Based on Alert Condition: Automatically Clear from Before 'Number of Bars to Calculate' (Automatically Clear from Before 'Number of Bars to Calculate') Set it to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-25 16:33:17
[2017-09-25 13:25:05] |
Thanks. Solved.
[2017-09-25 16:33:50] |
We clarified post #5 above.
