Date/Time: Wed, 15 Jan 2025 22:47:42 +0000
30 minute bar chart missing data YMZ17
View Count: 852
[2017-09-21 16:09:22] |
nth - Posts: 46 |
Using SC version 1568. Intraday data via BarChart. Previously working AOK until this AM. Vertical grid active but last grid line kicks in at 9/20/17 20:00 hours instead of typical midnight. Attempt to delete data and reload drops displayed bar data accumulated so far today and carries on picking up and displaying new data from time of "delete and reload". Suggestion??? nth |
[2017-09-21 17:47:40] |
nth - Posts: 46 |
Never mind... just confirmed "missing data" problem with Barchart. Best, nth |
[2017-09-21 18:04:25] |
You really should use the Sierra Chart Exchange Data Feed instead: Sierra Chart Exchange Data Feed We do not have any known users other than apparently you who are using the Barchart Data service directly now. With the Sierra Chart Exchange Data Feed, this data is not missing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-21 18:05:28
