Date/Time: Wed, 15 Jan 2025 22:35:42 +0000
Fix the column position of spreadsheet after new studies added/changed
View Count: 1067
[2017-09-21 15:35:49] |
User841591 - Posts: 42 |
I found that the position of the subgraph output column of the spreadsheet may be shifted if new studies or new subgraph in studies are added. My formula referring the subgraph are also required to changed manually. Could u advise the way to fix the column of the subgraph output or the formula can automatically refer to the shifted position so that I do not need adjust the formula for every change of the studies?
[2017-09-21 18:14:21] |
You need to reference the studies using this referencing method: Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
