Date/Time: Wed, 15 Jan 2025 22:40:01 +0000
STOCKS NOT UPDATING
View Count: 751
[2017-09-21 13:50:42] |
User608523 - Posts: 1 |
MY STOCKS ARE NOT UPDATING ON THE CHARTS, NO MOVEMENT AT ALL. ANY IDEA WHY?
[2017-09-21 18:16:17] |
This is because the service you are using does not provide real-time stock data. You will need to use the Sierra Chart Exchange Data Feed for real-time US Equities data if that is what you require. Refer to: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-21 18:17:40
