Date/Time: Wed, 15 Jan 2025 22:39:01 +0000
Study/Price Overlay issue
View Count: 1164
[2017-09-21 00:04:29] |
Devil_On_WallStreet - Posts: 67 |
I'm currently trying to overlay a linear regression channel from a higher time frame... The issue I'm running into is... It causes the bars to scrunch up because it's attempting to keep both the upper and lower lines of the HTF channel visible on the chart. How do I set it up so it doesn't do that and only shows them as price gets closer to them?
[2017-09-21 04:56:59] |
You need to follow the instructions here: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-22 19:56:45] |
For some reason it won't allow me to change the scale range to "Independent"... When I do, it lasts a second then changes back to "Automatic.?! Any thoughts as to how to fix this? This is also on an 8 Range chart... it lets me do it on both my 5 and 15 minute charts.
[2017-09-23 01:05:07] |
Instead of using an Independent scale you will want to use Same as Region. But you need to make this change on the source study in the source chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
