Date/Time: Wed, 15 Jan 2025 21:39:54 +0000
Question on Dom chart arrays
View Count: 565
[2017-09-20 23:06:08]
onnb - Posts: 662
I've been using drawing tools + subgraphs on dom charts.
Was wondering if you have these explicitly documented somewhere:
1) When using a dom chart, I noticed that I can sc.Index to draw with subgraphs and tools.
What do those indexes represent?
2) I noticed I can use sc.ArraySize
What is the ArraySize? Is it related to the days loaded and the timeframe like with a regular chart?
[2017-09-21 04:55:32]
A Trading DOM window is a chart that consists of 1 chart bar unless it contains studies. If it contains studies, then the number of bars it contains is going to be based upon the Chart >> Chart Settings.
The bar indexing and bar spacing in a Trading DOM window works just like any other chart. Although the bars are just not visible.
We will add the above information to the documentation.
