Date/Time: Wed, 15 Jan 2025 21:53:23 +0000
Full Contract Value Study
View Count: 726
[2017-09-20 21:11:57] |
infpz - Posts: 826 |
Seems to be using the tick value, rather than the full point value, to determine the result. For example it is displaying a value of 29,882 for NQ, which is 5 x the index. The correct result is $119,528, which is $20 x the index.
[2017-09-20 22:02:57] |
Yes, we see this mistake. This is now corrected. We will have a new release out tomorrow.
