Date/Time: Wed, 15 Jan 2025 21:44:56 +0000
Duplicate the chart including spreadsheet
View Count: 948
[2017-09-20 14:36:09] |
User841591 - Posts: 42 |
I duplicate a chart including a trading spreadsheet and then change the symbol on the chart in order to trade for another market. I find the symbol in the sheet cannot be changed even though I use "Find symbol and insert" in the sheet. Pls kindly help on it.
[2017-09-20 19:54:02] |
Check these study Inputs and make sure they are set to the particular Sheet that you want: Formula Source Sheet Number: Spreadsheet Study Inputs: Formula Source Sheet Number Chart Data Output Sheet Number: Spreadsheet Study Inputs: Chart Data Output Sheet Number When using the Spreadsheet Study, the command Spreadsheet >>Find symbol and Insert is not relevant. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-20 19:54:24
