Date/Time: Sat, 25 Jan 2025 05:26:41 +0000
30 year Bond Chart
View Count: 1098
[2017-09-20 13:30:40] |
User310550 - Posts: 7 |
Not sure what is wrong with this chart. The bar charts are skewed.
ZB Chart.PNG / V - Attached On 2017-09-20 13:30:25 UTC - Size: 120.88 KB - 296 views ZB Settings.PNG / V - Attached On 2017-09-20 13:30:34 UTC - Size: 46.06 KB - 292 views |
[2017-09-20 19:29:55] |
Follow the instructions here: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars And here: Chart Scale and Scale Adjusting: Resetting the Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
