Date/Time: Wed, 15 Jan 2025 21:39:20 +0000
grafical transaction history on the chart
View Count: 899
[2017-09-20 06:30:04] |
User882442 - Posts: 17 |
hello, could you add to options or maybe somewhere it is option to see on the chart only last trade. at them moment when im choosing show order fills on the chart there are all filled orders. and for this chart is illegible. look at the attachment i would like to see only last trade. when i make screenshoot to archive i need only last trade because i make screenshoot for each trade. |
Zrzut ekranu 2017-09-19 16.08.59.png / V - Attached On 2017-09-20 06:29:12 UTC - Size: 99.36 KB - 264 views |
[2017-09-20 07:30:57] |
There is a way to control the Start Date-Time of the order fills displayed on the chart. It is through this Chart >> Chart Setting: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-20 07:31:48
[2017-09-20 08:36:37] |
i opened chart setting and advanced setting and there is no date format and time format. but there is no ideal solution because for each transactions i will have to change date format. i would like to have universal solutions. |
Zrzut ekranu 2017-09-20 10.12.47.png / V - Attached On 2017-09-20 08:32:32 UTC - Size: 42.95 KB - 245 views |
[2017-09-20 19:50:54] |
You need to enter a Date and Time. We do not have any other easier solution now. But you can reduce the amount of data displayed on an order fill. Refer to: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
