Date/Time: Wed, 15 Jan 2025 21:34:14 +0000
I have started a fresh installation
View Count: 687
[2017-09-19 17:16:58] |
User677361 - Posts: 3 |
I have renamed the greenchart folder and have re-installed greencharts. After the installation.... I am missing all my chartbooks. Even the simple chartbooks are gone. Need to understand how to find or re-created these charts. Nothing online seems to help.
[2017-09-19 19:37:32] |
Follow step 4 here: Missing Files After Upgrading Software Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
