Date/Time: Wed, 15 Jan 2025 21:32:06 +0000
Direct account
View Count: 929
[2017-09-19 13:31:25] |
User740496 - Posts: 32 |
I have a trial account (now time expired) affiliated with a broker and $25 in credit. How do I now switch to open a new or direct account with Sierra excluding broker (and ideally transfer $25 across)? I tried opening a new account from scratch but it did not like me using same email address/name. Plan would be to pay for service pack 5 with Sierra in a direct account (not via broker).
[2017-09-19 17:50:24] |
You do not need a new account. Your Sierra Chart account has been set to no longer be affiliated with any broker. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access ----- We also temporarily activated your account for two days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-19 17:51:39
[2017-09-19 19:42:33] |
Great, thank you. Have updated usage time and will connect datafeed shortly.
