Date/Time: Wed, 15 Jan 2025 21:39:24 +0000
Move Main Chart to Chart Region 2
View Count: 1177
[2017-09-19 09:05:15] |
User172040 - Posts: 70 |
Hi, I have a main price chart and 2 indicator sets. Where do I change the settings so that the price chart is in chart region 2 and 1 of the indicators are in chart region 1. Please see attached what I am referring to
Chart Settings.PNG / V - Attached On 2017-09-19 09:05:06 UTC - Size: 59.31 KB - 354 views |
[2017-09-19 18:15:57] |
You need to use the Chart Region setting in Chart Settings: Chart Settings: Chart Region (List) (Chart >> Chart Settings >> Regions >> Chart Region menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
