Date/Time: Wed, 15 Jan 2025 21:58:32 +0000
duplicate chart to chart book
View Count: 1381
[2017-09-19 06:16:46] |
User745051 - Posts: 17 |
Hi guys, when I try this it sometimes has a mind of its own. Occasionally it works fine but there are times when I duplicate and then change symbol on the duplicated chart it also changes the other chart even though it is in a separate chart book. Am i doing this correctly? some markets are similar so I do not wish to change the study parameters nor layout... Thanks again. p.s. using latest SC |
[2017-09-19 17:28:34] |
Make sure the duplicated chart is not using Chart Linking: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber Set its Link Number to 0. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-19 17:47:45] |
thanks ill give it a go!
