Date/Time: Wed, 15 Jan 2025 22:00:13 +0000
Using GreenChart but having an issue with the analysis/greenchart, greenchart 1 options.
View Count: 1253
[2017-09-19 03:50:53] |
User677361 - Posts: 3 |
When I pull up a chapbook of aud/usd with several charts. I see what I hope is analysis/green chart 1. However, That option is not checked. It displays in all these charts our tnt/majors and minors, and the power indicators. When I go back to analysis and select "green chart" It switches my chart to candlesticks only, which it is suppose to do. The problem happens when I go back to analysis/green chart 1. I cannot swith back to the tnt/majors and minors,or power indicators. The charts just displays candlesicks. If I select analysis green chart 2. This displays smaller candlesticks and I think it is put/call options. Green chart 2 only displays candlesticks but should be displaying tnt/majors and minors, and power indicators. I do not know how to fix this. Hope this makes sense. |
[2017-09-19 05:48:33] |
Since you are using Study Collections from Green Chart we recommend contacting them. We really do not know how to answer this since we are not familiar with those Study Collections.
