Date/Time: Wed, 15 Jan 2025 21:37:13 +0000
Linux, tradewindow and the new change of destroying windows when changing chartbook
View Count: 1395
[2017-09-18 22:56:36] |
AlexPereira - Posts: 197 |
Hi, I have been using SierraCharts in linux, and worked around the tradewindow bug by not closing the tradewindow or including it in a chart/tradedom. With this new change of windows being destroyed when changing chartbooks, makes SierraChart almost unusable in Linux, because even when not closed or attached in a chart/tradedom, it now triggers the bug of the tradewindow in Linux. What solutions there is or workarounds ? I would really like to continue using SierraChart in Linux. Thanks. |
[2017-09-19 00:04:16] |
What we can do is make this new feature an option.
[2017-09-19 07:21:18] |
Hopefully the Linux bugs will get fixed someday, but I guess "making destroying windows an option" is enough for me to continue using SierraCharts on Linux. I also don't have problems with memory usage and switch chartbooks alot, so not destroying and creating windows all the time will probably save a few cpu cycles. Thanks! |
[2017-09-19 15:31:36] |
User75096 - Posts: 48 |
Please make this new feature an option. Sierra was fine with linux, now a desaster, thanks and kind regards
[2017-09-19 16:01:50] |
ganz - Posts: 1048 |
+1
[2017-09-19 19:21:16] |
For the time being we have released version 1613 which does not destroy chart Windows when they are hidden. Use this version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-19 20:22:30] |
thanks alot
