Date/Time: Tue, 22 Sep 2026 04:05:39 +0000
multiple T3 averages using ASCIL
View Count: 1859
| [2017-09-18 21:53:56] |
| bala - Posts: 74 |
Hello, Here is the situation. I am trying to create two T3 moving averages (say length 20 and 10). Manually I am able to create them but I have a problem when I try to create them using ASCIL within the same study. I am able to draw the first average but the computation fails for the second average. The reason I suspect is that the variable sc.DataStartIndex has been set for the first period and is unique for each period. Please note that there is NO sc function to create a T3. (similar to sc.SimpleMovAvg() ) 1. Am I correct that the problem is because of sc.DataStartIndex? 2. So we cannot create two T3 with different periods using ASCIL? 3. Please add to the ASCIL library a function for creating T3 ( sc.T3() ). Thanks |
| [2017-09-19 18:24:00] |
1. No definitely not. There is some problem in your code. 2. You most certainly can do this calculation using ACSIL. 3. We will see about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-09-19 18:41:16] |
We are going to add a sc.T3MovingAverage function to ACSIL today.
