Date/Time: Wed, 15 Jan 2025 21:34:40 +0000
switch from 100 symbol to 10 data connection
View Count: 1209
[2017-09-18 16:46:24] |
User316362 - Posts: 210 |
I currently have a 100 symbol data connection. If i want to switch to 10, can i simply set it to 10 and on monthly auto renewal (on the 1st) the price will automatically adjust?
[2017-09-18 17:37:31] |
Sierra Chart - Max - Posts: 5778 |
The 10 Symbol Limit will be in effect immediately. So if you still need the 100 Symbols this month, then you would want to change to 10 symbols closer to the end of the of the current month.
Sierra Chart Support |
[2017-09-18 20:46:48] |
I assume TICK-NYSE, UVOL-NYSE etc are counted as symbols? Also If I'm at my 10 limit and stop using one symbol...i assume i can replace it with another? And all back data is maintained on rollover to new symbol? Thanks, |
[2017-09-18 20:57:20] |
Those particular symbols do not count towards the Exchange Data Feed symbol limit. Refer to: Chart Data and Chart Data Files: Reducing Number of Symbols Being Tracked by Sierra Chart And all back data is maintained on rollover to new symbol? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-19 13:47:15] |
Is there a tool or a way to see the number of counted symbols one is using versus manually?
[2017-09-19 17:45:36] |
Sierra Chart does indicate the total number of symbols it is tracking in the status bar. Refer to: Status Bar We cannot provide further help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-19 17:45:43
