Date/Time: Wed, 15 Jan 2025 21:34:12 +0000
Show order fills with market profile - uncorrect alignment
View Count: 1066
[2017-09-18 16:23:40]
User877753 - Posts: 152
The "Show Order Fills" instruction works perfectly with all charts, except Market Profile.
Orders are aligned on the far right, instead of pointing to the correct period.
I uploaded chart : http://www.sierrachart.com/image.php?Image=150575153098.png
Works fine with 5 mn chart :
http://www.sierrachart.com/image.php?Image=1505751717158.png
I suspect this has to do with the particular buildingof MP charts, eg each column is aligned to 1 second (I noticed that trying to use Drawing Tools within MP charts).
Is there any clean way to correctly align Order Fills with the correct period ?
JM
[2017-09-18 16:29:10]
No there is no way for us to solve this. You cannot display order fills on a TPO Profile Chart. This is logically impossible. Or use drawing tools other than tools that use horizontal lines.
[2017-09-18 16:41:03]
Well, I used oblique arrows, but it's clumsy.
Too bad for order fills on MP.
Thank you anyway
Keep on the good job with Sierra Chart, this software is great !
