Date/Time: Wed, 15 Jan 2025 21:47:49 +0000
Display Chart Values on the chart
View Count: 840
[2017-09-18 15:08:19] |
User514370 - Posts: 62 |
Hi SC, is there any way how to display some data from Chart Values directly on the chart (without openning Chart Values window)? Specifically, I want to see "Ask - Bid Volume Above/Below POC" from VbP study, so this is can not been done by Text Display For Study. If this is not possible, may I ask you to consider add "Ask - Bid Volume Above/Below POC" to VbP study (in the same way I can display "Display Entire Profile Volume (In:94)", etc.)? Thank you! |
[2017-09-18 18:25:04] |
No, and this is not something that we would add.
