Date/Time: Wed, 15 Jan 2025 21:56:41 +0000
following my query in reference with "Read Only" APIs ...
View Count: 763
[2017-09-18 14:40:36] |
jizzary - Posts: 177 |
I have noticed that if I change an attribute of a subgraph (like color, width, enable a label) a recalculation is invoked. I think the changes should be distinguished to values affecting and non-affecting in order to minimize the need for recalculation. I have no idea whether it complicates the code but from user standpoint this is annoying and I think it is unrequired. If possible to fix it sometime in the future it will definitely be of assistance. Thanks. Date Time Of Last Edit: 2017-09-18 14:42:29
[2017-09-18 16:17:56] |
There is no chance whatsoever of this happening and it is tremendously complicated and on top of that it definitively will cause malfunction of certain types of studies.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-18 16:18:18
