Date/Time: Wed, 15 Jan 2025 21:47:12 +0000
Date format and importing data
View Count: 991
[2017-09-17 07:42:34] |
User521791 - Posts: 12 |
Hello, I'm trying to import data from a text file. The fields format is as follows: "Date","Time","Price","Volume" 20/03/2017,23:00:00.418,2374.25,2 The import goes thru but the dates are incorrect, I'm assuming Sierra was expecting to see 03/20/2017 instead of the above. Is there a way to fix this inside Sierra? The file is a single ES contract, size 757 Mb, Excel shows an error msg there are too many records. |
[2017-09-18 17:27:58] |
The supported Date formats are documented here: Text/CSV Data Format: Date Format We will see if we can quickly and support for this other date format but we do not want to make any promises. We are overly busy at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
