Date/Time: Wed, 15 Jan 2025 21:36:52 +0000
sc.GetChartSymbol () during DetDefault block
View Count: 1046
[2017-09-16 20:08:33]
jizzary - Posts: 177
Is there any reason why sc.GetChartSymbol() returns nothing when called inside the SetDefaults block?
(it is called for the hosting current chart)
Thanks.
Date Time Of Last Edit: 2017-09-16 20:09:15
[2017-09-16 22:35:03]
We will solve this in the next release.
The problem though is if a study function in the sc.SetDefaults block is making a function call which is altering some variables in the chart, then that is going to affect the chart even before using OK/Apply on the Chart Studies window and that would be unexpected for the user.
Date Time Of Last Edit: 2017-09-16 22:35:14
[2017-09-18 07:02:38]
Hi
I do understand your concern.
The question whether you are going to enable all passive APIs (i.e. read-only APIs) in the SetDefaults block
or just the API in the subject?
I think the documentation needs to be updated for ALL APIS - to indicate which are blocked during SetDefaults block.
The reason I asked is since documentation didn't reflect it.
what will be the next release number? 1610 ? 1611 ?
Thanks.
Date Time Of Last Edit: 2017-09-18 07:02:53
[2017-09-18 07:57:06]
Yes.
Version is 1612.
