Date/Time: Thu, 12 Nov 2026 20:33:23 +0000
[User Discussion] - Backtest doesn't work as expeted
View Count: 1122
[2017-09-16 18:41:04]
ubarolo - Posts: 1
I'm testing this simple trading system that buy the highest high of 5 days back.
float h = 0;
  SCFloatArrayRef Highs = sc.BaseData[SC_HIGH];
  if (sc.Index > 5)
    for (int i = sc.Index - 5; i < sc.Index; i++)
      if (h < Highs[i])
        h = Highs[i];
  //LONG
  if (h>0 )
    // Create an s_SCNewOrder object.
    s_SCNewOrder NewOrder;
    NewOrder.OrderQuantity = 1;
    NewOrder.TextTag = "Trading example tag";
    NewOrder.OrderType = SCT_ORDERTYPE_STOP;
    NewOrder.Price1 = h;
    NewOrder.Target1Price = h + TargetValue.GetFloat();
    NewOrder.Stop1Price = h - StopValue.GetFloat();
    Result = sc.BuyEntry(NewOrder);
    //Result = sc.BuyOrder(NewOrder);
    //If there has been a successful order entry, then draw an arrow at the low of the bar.
    if (Result > 0)
      r_EntryInternalOrderID = NewOrder.InternalOrderID;
      SCString InternalOrderIDNumberString;
      InternalOrderIDNumberString.Format("BuyEntry Internal Order ID: %d", r_EntryInternalOrderID);
      sc.AddMessageToLog(InternalOrderIDNumberString, 0);
      BuyEntrySubgraph[sc.Index] = sc.Low[sc.Index];
I don't understand why in the case attached it doesn't work.
Can you help me?
Date Time Of Last Edit: 2017-09-17 10:36:20
image2017-09-16_20h38_14.png / V - Attached On 2017-09-16 18:40:04 UTC - Size: 13.9 KB - 454 views
