Date/Time: Wed, 15 Jan 2025 21:47:55 +0000
charte region - substudies display
View Count: 944
[2017-09-16 16:04:53] |
User30743 - Posts: 365 |
how do i adjust substudies - i have this chart - see the attachment - and bellow that chart in the chart region 2 i have 2 substudies. what i need is one to be showed above the horizontal line and the other bellow horizontal line (in the same chart region). how do i do it? Date Time Of Last Edit: 2017-09-16 16:06:44
sierra.png / V - Attached On 2017-09-16 16:06:41 UTC - Size: 29.35 KB - 267 views |
[2017-09-16 23:12:11] |
Refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-19 14:50:16] |
hm.. it is so compicated. i couldnt find it there
[2017-09-19 17:42:06] |
The name of the section we linked to is called Study Display Order: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-19 17:42:20
