Date/Time: Sat, 25 Jan 2025 05:32:02 +0000
Use WebCQG for quote and IB for trade
View Count: 1037
[2017-09-16 15:24:28] |
User841591 - Posts: 42 |
I suppose to use IB as trading service provider without quote subscription and make use the quote from WebCQG. I have followed the link below to create 2 instance of SC. One is for WebCQG and the other is IB. However, I cannot still find the way how the IB instance to get the quote from WebCQG instance in order to trade on the chart mode. Pls kindly help on it. Using Multiple Data and Trading Services at the Same Time |
[2017-09-17 02:31:35] |
For what exchanges did you want to do this for? If it is for one of the exchanges supported by the Sierra Chart Exchange Data Feed, then the proper solution is to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed However, what you want to do is explained in this section here: https://www.sierrachart.com/index.php?page=doc/FileMenu.html#FileFindSymbol_OpenChartFromAnotherInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-17 02:31:59
[2017-09-17 12:33:02] |
Thank you for your help. I want to trade in HKFE but SC told me I need to apply through a course organised by Ricky Cheung. The fee of Datafeed from this course is terrible high. If SC can offer the Datafeed of HKFE with the package price, I definitely subscribe it. BTW, is it possible that I can get HKFE datafeed without applying the course or may be possible in some day?
[2017-09-18 19:47:51] |
OK we understand now. It may be possible someday but not now.
