Date/Time: Wed, 15 Jan 2025 21:52:53 +0000
Cannot Connect to GAIN Capital OEC feed
View Count: 1335
[2017-09-16 14:46:17] |
Fuming - Posts: 10 |
I am not able to connect to my GAIN Capital OEC data feed. This was working the past couple weeks during my Sierra Trial. As of last night, I am getting the errors shown in the attached text file. Thanks for any help! Jack |
[2017-09-16 16:21:24] |
User99934 - Posts: 227 |
Hi Jack, They shut off the GAIN feed after the market closes on Friday night and it starts again on Sunday evening. I experienced many problems with the GAIN feed and eventually transferred to the Sierra/CTS feed and much happier. |
[2017-09-16 16:30:23] |
Oh I see thank you for your reply. When I saw the errors, I didn't think to open up the charts. The historical download of data worked just fine. Thanks again.
[2017-09-16 23:13:23] |
Refer to: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ServerAvailability Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
