Date/Time: Wed, 15 Jan 2025 21:46:48 +0000
SPreadsheet function - bars since entry
View Count: 1827
[2017-09-16 03:24:39] |
vectorTrader - Posts: 86 |
I am trying to use a spreadsheet since I do not know how to code in sierra. I am trying to take trades and then exit based on x bars later. Is there a way to do that? I tried counting the number of bars $j$8>0 but that always gave me 1000. I cant seem get it right.
[2017-09-16 19:07:06] |
Sawtooth - Posts: 4153 |
J8 is not relative to any one bar so you'll need to count bars since the entry signal's bar with a formula like this (for long entries), e.g. in cell P3: =IF(K3,0,P4+1) Then reference P3 in your exit formula: =AND($J$8>0,P3>=5) This only works if signals are at close of bar. |
[2017-09-17 03:06:19] |
What about using the elapsed time since entry? That can be calculated.
[2017-09-17 23:24:25] |
I cannot use time based as my strategy is using volume bars. Its great to know MFE buy I am looking for signal decay and knowinfg how many bars to MFE is very helpful.
